Horn Relocation for FLSTFBS
Old 07-24-2016, 04:09 AM
user 46092's Avatar
user 46092
user 46092 is offline
I needed to pass inspection so I attached my OEM horn to the mounting bracket for that crappy horn. I'm probably going to go with a mini beast. In the next week or so near that same spot. Docking hardware for my detachable HD Fat Boy saddlebags might cause a problem. I wish I never got them.
  #32
Old 09-05-2019, 06:59 AM
Pyro451's Avatar
Pyro451
Pyro451 is offline
Finally got this accomplished with the stock horn mounted right side by the exhaust as pictured here. Good thing the pipes are loud 'cause I can't hear the horn anymore while I'm accelerating.
Also, DK Customs was very helpful in solving a problem I had with the SE wires. They are VERY tight on the '16 FLSTFBS. DK swapped them out for a set of 409 wires that are slightly longer and have a less obtuse angle on the boots. That gives enough slack to eliminate worries about stressing the boots or plugs. I installed the mid-frame air deflector at the same time. No days above 80°F since then so I can't tell how much difference it really made in temps.
  #33
Old 09-08-2019, 01:30 PM
Sparky357's Avatar
Sparky357
Sparky357 is offline
If you want real results skip the HD deflectors and go straight to the Captain Itch deflectors.
  #34
Old 05-28-2021, 10:37 PM
Michael Mozzie's Avatar
Michael Mozzie
Michael Mozzie is offline
Stage I
Default Thanks for the pic mate just did the same to my bike your a legend
Originally Posted by Gaz B
Don't know if you can do the same on an FLSTFBS but on my 09 FXSTC I've tucked it away on the right hand side just behind the transmission.
Cozz
07-28-2016 06:03 PM
mydogfarted
04-16-2016 07:35 AM
wake83
02-02-2014 08:13 AM
spydyr
04-03-2012 10:26 PM
DanDeuce
05-02-2008 04:37 AM
Quick Reply: Horn Relocation for FLSTFBS
