Do you wait 5,000 between oil changes?
#31
I change my oil every 4500-5000 miles (for me that is between 7200 to 8000 Km).
I change my primary oil every other oil change.
And The tranny only every 2 years (generally every 20K) only because I have shotgun shocks and have no access to the tranny bolt so this one my Mechanic does when we change tires.
I have 67K so far and no complaints.
#33
And that used synthetic oil? I keep it clean in the draining process (suck it out with a vacuum pump siphon) and pour it into the fuel tanks on my diesels to mix with the #2 fuel - eases the wear on the pumps and injectors attendant to the low sulfur fuel we now are obliged to buy... (Mostly, depending on need, I use 30# bar oil for this too.)
I am curious about how many add top oil and/or stabilizer to their gasoline? (I do, fyi)
