Just ordered LED turnlights for my 2015 Fat Boy
Old 05-09-2016 | 10:20 PM
Gommee's Avatar
Gommee
Devil's Advocate
Is anyone that have the CD front LED or LED Ringz getting any codes or the dash signals flashing fast?
I want to order the CD Rinz, but all of the LED I have put in the front make the dash signal blink fast and have thrown codes due to the low resistance. The codes I can live with, but fast flash on the dash drives me crazy, kind of a pet peeve.
All of my other lights are LED: Alloy Art strut signals, Low profile tail light, Auxiliary lamps, and head light. Only place I am running incandescent are front signals.
Old 05-09-2016 | 10:59 PM
jbfb's Avatar
jbfb
I have the CD TruWRAPZ. Dash light blinks fast. Doesn't bother me in the least. 14 FBLo
Old 05-10-2016 | 05:00 AM
Pyro451's Avatar
Pyro451
Once you have enough LEDs, even in the newer bikes you can start throwing codes. Once you clear the codes you can follow this procedure to sync the LEDs to the ECM. (Courtesy of Custom Dynamics). Worked for me.
1) Turn ignition ON.
2) Turn on 4 way hazards by pressing the hazard button on the controls. Do NOT press both turn signal switches at the same time. (That is the way the hazards activate on Pre CANBUS bikes).
3) Turn the Ignition OFF letting hazards run. If the bike has security alarm, they will flash 5 or 6 times and then pause -this is normal. They will return to a normal hazard mode.
4) Let hazards run 1-2 minutes.
5) Turn ignition back ON.
6) Turn off hazards.
7) Turn ignition OFF and then back ON.
8) Check function of turn signals.
9) If dashboard indicators still flash rapidly, you will need to pull the codes (see attachment- Clearing DTCs on CanBus Models).
RLTW79
08-03-2014 09:56 AM
artsbest
09-18-2012 10:27 PM
jimrglide17
Electrical/Lighting/Alarm
09-25-2011 12:29 PM
zukeeper
09-25-2011 11:15 AM
t059736
12-03-2010 09:39 AM
Quick Reply: Just ordered LED turnlights for my 2015 Fat Boy
