2011 Heritage Softail Classic- Start Problems
2011 Harley-Davidson FLSTC - Heritage Softail Classic- I am having intermittent starting problems. When I turn on the main switch, oil pump, lights, everything works. Next I switch on handlebar engine kill switch and then push start switch and nothing happens. Try again and sometimes it will engage starter, sometimes takes several attempts. Sometimes, it will work, no problem. Problem is intermittent. Sounds like handlebar starter switch problem, but where to start without replacing everything?? Anyone else experience same? Getting ready for long ride and would like to eliminate issue before I get stuck somewhere. I have had to kick start on more than one occasion.
Check out the link below that Joe wrote up. It may not be your problem, but it definitely shouldn't be overlooked in your evaluation. When ever some one tells me about an intermittent electrical issue they are having, I always tell them to check the switch first. Believe it or not, 8 out of 10 times the switch fixes it.
https://www.hdforums.com/forum/softa...le-riding.html
Dave E (05-12-2016)
Had similar issue before. Intermittent starts. Check your starter relay. They go faulty. Easy $7 relay replacement and spare.
And I also added solenoid starter button cover to bypass the switch and relay if they ever became an issue again.
Dave E (05-12-2016)
