Softail forward controls install
First you remove your forward controls (I would leave the brake line hooked up but loosen any clamps along the brake line). Install the extension plates on the frame at the stock mounting points. Then attach you forward controls to the extension plates. If the brake line doesn't have enough slack you may have to get a longer line. Install the extended shift linkage. I would use blue Loctite on all the bolts. I hope this helps you out.
Thank
thoner7
06-21-2016 04:34 PM
