CVO Breakout
But really funny you're knocking the "big wheel" Breakouts because that disproportionately larger wheel is one of the main stylings of a Pro Street type of bike, and has been a key element to the BO's specific model line since introduced. that's why so many of us were doing the "WTF" with the small wheel as it changes the overall look of the bike. the rest of the bike is very nicely done.
Here's some info on the Pro Street heritage and typical styling associated with this type of bike.
http://www.custom-choppers-guide.com...-choppers.html
http://www.cycleworld.com/2014/05/20...om-motorcycle/
http://auto.howstuffworks.com/chopper-profiles6.htm
FXSE (03-29-2016)
So I swung through the HD site to see if they had the new CVO seat as an option for other models. Didn't see it...but I saw a solo bobber seat listed as a CVO option...but not for any other models. Would they have seriously made a CVO that different so you can't have compatibility with other breakout models?
Here's some info on the Pro Street heritage and typical styling associated with this type of bike....
... http://www.cycleworld.com/2014/05/20/paul-jr-designs-pro-street-
One cosmetic change I'd make is going with true clip-on handlebars, versus the "clubman" bars. Another practical change I'd make is mid controls, to fit better with the forward-lean riding position.
I think that one's a darned nice looking bike. Can't see any reason why it couldn't be built around a suspension frame (rather than being built on a rigid frame) to make it a "rider", as opposed to a show bike.
What would it take to get the inverted forks from the prostreet breakout added to a earlier standard breakout? Then you keep the 21 in front but have inverted and more blacked out front forks. Obviously the forks would not be cheap but what else would be involved in that kind of a swap?
Michael
Michael
Yup, I saw that the other day too.... it's a beauty!
just a real basic guess- the forks should fit the frame ok, you'd need to revise the fender mount so it clears a 21" wheel, need to make sure a dual disc setup can go onto your 21" wheel- or do away with the fork right side caliper. not sure what effect that may have on the ABS or overall braking up front though. maybe re-use your stock caliper and master.
Might be better to get a set of inverted forks from Ohlins special order like they did for the SSR Breakout (google it if you have not seen it), or a set of Ceriani's, or a set of Mean Street forks. Any of these three would be superior in performance and sleeker looking than the HD setup. Here's a related thread: http://www.clubchopper.com/forums/al...ront-ends.html
