Rocker B: MY ROCKER C MOD THREAD
#731
You filter setup looks great. I have my filter running under the bike. I only have 4400 miles on my bike and I've changed the filter a few times already. Cheap filter , easy to change. Never had any oil dripping from it. Maybe I didn't need to change it but after it looks dirty I do it anyway.
Rocker B (11-28-2017)
#732
Below I've posted links for the individual parts that made up my external breather "kit" (page 72), and a few more pics of them assembled and installed on the bike.
I purchased the main components on Ebay, and these sellers had the lowers prices when I ordered. The chrome worm clamp and black T can be found at your local hardware store.
1/4" Hose Barb to 1/8" NPT 316 Stainless Fitting: https://www.ebay.com/itm/1-4-ID-Hose...VYsJN-&vxp=mtr
6AN Braided Stainless Steel Fuel Line: https://www.ebay.com/itm/6-AN-3-8-Br...73ZcvA&vxp=mtr
Spectre Chrome Hose End Clamps #2168: https://www.ebay.com/itm/Fuel-Line-F...lTmc90&vxp=mtr
Golan Finned Transmission Breather/Collector: https://www.ebay.com/itm/GOLAN-FINNE...-/332269016129
The following 2 users liked this post by Rocker B:
Sarah93003 (11-24-2017),
splattttttt (11-23-2017)
#733
I've decided to switch out my foot and shifter pegs again....Battistinis Custom Cycles now makes pegs with "oval" holes, so I ordered a set and will be replacing my current Arlen Ness 10 Gauge pegs.
I've been looking for a while now, and these are the first pegs I've seen with beveled cut oval holes, which should match nicely with the beveled cut holes in my wheels and pulley!!
Sarah93003 (12-14-2017)
#734
do you ride that bike??, theres like ZERO wear on those brake discs? lol...its beautiful man, u know im playing!
gota a quickie the 3 rear spacers that go on rear Axel, large one is on pulley side, than other side BEFORE rear brake caliper holder its the larger of the last 2, there almost equal, im sure you know what I mean, got them all harley chrome, right part numbers, I just dont like how that caliper holder is "sitting" on the ledge? can you post a pic of your please, as so I can see how DEEP that caliper bracket has to sit, thanks brother
#735
also what carb do you have,Stock 46mm? im sending my heads BACK to get ported to 1.80 and going Horsepower 58-62?just not sure if it needed, I buy lots of stuff, that I dont use????
funny I was looking at those exact basstini's foot pegs etc,lol,Went w/ Arlen Ness Deep Groove chrome instead..look great, regretting my decision!
#736
The larger spacer on the right side goes against the wheel/hub, and I took a pic of the caliper mount sitting on the ledge, it's hard to get a good pic, but hopefully it helps...
Yes, stock.
TOMMYBLAZIN (01-03-2018)
#737
#738
#739
[QUOTE=Rocker B;16908301]Here's a list of the parts and quantities needed for the Deuce console mod, keep in mind that it also requires a larger, 4 1/2" speedo, not the Rockers stock 3 3/8".
That just sunk my ship.
Had I known I would have bought the appropriate speedo. What waste. Anybody need a speedo installed for 2 hours. Man I wish I knew. Now I have an obselete speedo. K thanks. When people say the can swap the dashes over they should somewhere mention the speedo diameter. 50% off no box. ****....!!
#740
