Rocker B: MY ROCKER C MOD THREAD
Old 08-27-2016 | 10:37 AM
Sarah93003's Avatar
Sarah93003
Originally Posted by Rocker B
Well, I had been thinking about it.......It's now ordered and shipped!!
....I also had to order a new clutch cable. The Magnum Shielding cable is defective and has a small/slow leak at the chrome fitting on the tranny end that eventually runs down and drips off the cable. They had me send them a pic and I'm hoping they will cover it under warranty and give me a credit...
[/IMG]
That rocks!!
  #512
Old 09-03-2016 | 12:28 AM
Rocker B's Avatar
Rocker B
I got the chrome rear master cylinder, and was waiting for the new clutch cable so I could do them at the same time.....it showed up today, so I should have them installed soon!!
Here's a couple pics from when I started the thread, and a few new ones....
j33ptj (09-05-2016)
  #513
Old 09-03-2016 | 02:00 AM
stinkerbill's Avatar
stinkerbill
I got say I'd never been a big fan of the Rocker... To me the line just never flowed right
But that looks ace!
It now flows so much better... Just looks... Right
Nice one. I'm seeing Rocker Cs in a new light. Which is the sign of great customising
Rocker B (09-22-2016)
  #514
Old 09-03-2016 | 11:57 PM
Sarah93003's Avatar
Sarah93003
Such and awesome transformation! If you ever head South, let me know, that would be a cool photo op.
  #515
Old 09-22-2016 | 08:11 PM
Rocker B's Avatar
Rocker B
So, I got around to switching out the leaking clutch cable, no problem, then I installed the new chrome rear master cylinder....that's where I ran into an issue, I got all done, took it for a test ride and when I got back the pads were smoking, and the rotor was burning hot. The brakes were engaged with the pedal up. Well, after trying several times bleeding and then flushing the brake line, then taking the calipers apart to try to figure out what the hell was wrong, I decided to take the new master cylinder apart and found the problem. The hole in the bottom of the reservoir had not been drilled all the way through, so the cylinder was able to push the fluid back to engage the brakes, but it couldn't come back, the pressure keeping the brakes on like I was pushing the pedal (It even had a sticker on it saying it was factory tested, ya right!!).. I drilled out the hole, put everything back together, and it seems to be working fine now.....but, a 1hr. job turned into a day and a half. LOL!!
Here's a pic, Ill take and post a few better ones tomorrow...
  #516
Old 09-23-2016 | 12:44 AM
Sarah93003's Avatar
Sarah93003
It really looks awesome! You've got great skills. That was excellent troubleshooting.
Rocker B (09-23-2016)
  #517
Old 09-23-2016 | 01:13 AM
EagleRay's Avatar
EagleRay
Thumbs up! Good work. But what a PITA. I think I wouldn't have figured that out! Neither would I've been able to solve it myself....
What about your rotor, did it suffer any decoloration due to the heat. I had my rear brake pads/pistons stuck once due to wrong lubricant that happened to burn up and block the pistons from moving. Result....my nice chrome rotor went all yellow.
Rocker B (09-24-2016)
  #518
Old 09-23-2016 | 01:30 AM
Rocker B's Avatar
Rocker B
Ya Ray, it sure did, turned it yellow/brown around the outside edge. Luckily with the stainless rotor I was able to use sand paper to clean it up, I was surprised how well it actually worked, looks fine now....
  #519
Old 09-24-2016 | 12:10 AM
Rocker B's Avatar
Rocker B
Here's a few more pics with the new chrome rear master cylinder..I don't have anything else planned, so I think that's it!!!..... for now anyway, LOL. I'll eventually get to the motor mods, cams for sure, maybe more!! ... probably wait a few months until it's cold and rainy though...
  #520
Old 09-24-2016 | 12:36 AM
Ink83's Avatar
Ink83
Looking more like sexy chopper now! Good work man!
Quick Reply: Rocker B: MY ROCKER C MOD THREAD
