Rocker B: MY ROCKER C MOD THREAD
Old 06-20-2016 | 10:13 AM
Rocker B's Avatar
Rocker B
Originally Posted by skid_pimp
I'm running it around their fat 21, with a 120 metz. It's snug and it is prebent mounting flanges for the Rocker front end, no spacers or anything needed. It's roughly 5.45 inches wide around the tire. Thanks, I think it complements my paint nicely
OK, so the off-set is built into the flanges, (like the stock fender) so it's centered with the tire, right?? Do you have a pic from the front??... I'm thinkin this might be the way I go!!
  #312
Old 06-20-2016 | 11:10 AM
skid_pimp's Avatar
skid_pimp
Correct, I might, I'll look and if not I will snap one for ya
  #313
Old 06-20-2016 | 11:17 AM
skid_pimp's Avatar
skid_pimp
I'll take a straight on tonight, I'm thinking that's what you are looking for. This is all I have right now. They are old, but show the fender and wheel/tire combo.
  #314
Old 06-20-2016 | 06:23 PM
skid_pimp's Avatar
skid_pimp
Here ya go, hope these help your decision. The front end is loose and the front signals are dangling, but there is a front shot of the fender.
  #315
Old 06-21-2016 | 01:09 AM
Rocker B's Avatar
Rocker B
Ya, that helps, thanks man!!.....
I didn't get a chance to do much over the weekend, was hoping to finish up today, but I got a late start and my garage was 90+ degrees by 11a.m., so I didn't spend much time on it. I hope to get an earlier start tomorrow before it gets too hot!!.... I've got the rear shocks and rear wheel/tire installed. I also removed the fender license plate mount, buffed out the rub marks it left on the fender and pulled the wire that ran inside the fender to the plate light and re-routed it along the inside of the swingarm, back to the new, side mount, plate holder...Still need to install the Progressive front springs/lowering kit, front wheel/tire and axel covers, then raise and re-install the front fender (might be temporary) and adjust the rear height with the 422's.....
Teaser pic...
I started playing with designs for the vents on the chin spoiler...Here's two looks, the top tape dot is about where the hole for the mounting bolt will be... I think I like the 2nd one.....with MORE SLOTS!!!
  #316
Old 06-21-2016 | 01:53 AM
EagleRay's Avatar
EagleRay
Yeah I agree...the 2nd one with more slots looks very nice. Go for it!
  #317
Old 06-21-2016 | 01:54 AM
j33ptj's Avatar
j33ptj
I would match the slots in the chin spoiler to the wheel spokes....
  #318
Old 06-21-2016 | 03:30 AM
skid_pimp's Avatar
skid_pimp
Agreed, the second pattern is better. You might even be able to pull off thinner slots in the same general shape, but two or three slots in each line length if the slots were thinner. Just an idea to try and give you as much airflow as possible
  #319
Old 06-21-2016 | 03:58 AM
Nostradamus74's Avatar
Nostradamus74
Teaser pic...
Yep, I agree, 5 vertical lines pattern looks much better other than keeping voltage regulator cooler.
If you manage to make some slots instead of continuous lines it'd look even better!
  #320
Old 06-21-2016 | 04:07 AM
Nostradamus74
Somethin like this...lots-of slots!
Attached Thumbnails Rocker B: MY ROCKER C MOD THREAD-editedspoiler.jpg
Quick Reply: Rocker B: MY ROCKER C MOD THREAD
