10 inch Mini Apes on Slim???
slimmrider (03-09-2016)
You may get by with not swapping anything but the front brake line? It will be kind of a roll of the dice.
I had my bars all wired up and installed on the bike and tried hooking up the stock clutch and throttle idle cables to cheat the kit. (The standard 1" mini apes with 1" risers may work?)
The clutch reached but was tight, the throttle idle cables were a no go, not enough slack. I bought everything through Harley as a kit to install the HD fat mini apes. Very easy
Only drama was doing it on my condo patio.
I just swapped my slim stock bars, to the HD Fat mini apes. These have a 3 inch riser then the bars
