Slim...what's neede for Forward Controls Swap
Old 03-03-2016, 08:42 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
Default Slim...what's neede for Forward Controls Swap
So I wanna swap my floor boards for forward controls. Found a set of brackets only. If I get the brackets, what else do I need that's not reuseable?
It looks like all the shifter linkage on the left side would swap over, but I'm not sure.
I know I'd need pegs and a brake pedal, but that's easy enough.
What about the master cylinder; will the stock one make the swap?
Old 03-03-2016, 09:56 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
Cheapest way would be trading someone for forward controls.
Old 03-04-2016, 10:00 AM
BlessedHellride's Avatar
BlessedHellride
BlessedHellride is offline
Stock master cylinder will work, but you will need to get an FX style rear brake lever that goes under the foot peg mount of the FX brackets (the FL lever would be over the top side and won't depress, obviously). The FL brake lever won't work, it won't line up with the piston on the master cylinder, either. Might be the same with your shift lever, too, I never tried to use the FL shft lever but it could work.
Old 03-04-2016, 12:46 PM
Sinthroid's Avatar
Sinthroid
Sinthroid is offline
Default controls
Stock Brake pedal will work galaxyfe.
Old 03-04-2016, 05:15 PM
Bamjoop's Avatar
Bamjoop
Bamjoop is offline
Harley part number 33909-08A and any standard pegs then.
Old 03-05-2016, 07:07 AM
BlessedHellride
The pedal would work, but if your talking about the brake lever/arm I'm pretty sure it won't. If you got an FL style lever to work with FX style brackets, post up a pic I'd like to see this and would be nicely surprised.
Old 03-05-2016, 10:51 PM
blkline69's Avatar
blkline69
blkline69 is offline
I'm looking for floorboards and controls. pm me if you are interested in a trade for my forward controls man.
Old 03-08-2016, 06:53 PM
Mercizizou's Avatar
Mercizizou
Mercizizou is offline
I also want to trade someone with floorboards for my forward controls. I have a 2014 Breakout.
Old 03-08-2016, 09:04 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
Swap compete. Nothing else needed.
Old 03-08-2016, 11:39 PM
stal94gt's Avatar
stal94gt
stal94gt is offline
I wanted to thank galaxyfe for doing the swap with me. Just some information on the swap. Brackets from my 07 night train were a direct swap to the 15 slim boards. Really the only things that had to be swapped were the brackets and brake lever. Everything else can stay the same. The swap was easy to do you can reuse the hardware, shift lever, shift linkage, and master cylinder
rockabillygrl (06-15-2016)
Quick Reply: Slim...what's neede for Forward Controls Swap
