Measurements on rear fender
Atomicar, Before @ 2006, the Fatboy and Heritage (and Deluxe except for tail light) fenders are interchangeable. Same 7 1/4" width. (I know I have swapped them).
Some years back Harley made the Fatboy rear fender MUCH wider. (@2006-7)?
You will not see this measurement on the parts diagram, you would see the part # change on the Fatboy rear fender by changing years: This might help:
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Edit: This info is for 2005 to present bikes. I think there have been some changes prior to this I have not delt with.
It looks like @ 2007 Harley went to the 200mm rear tire and Wide rear fender:
https://www.hdforums.com/forum/softa...-rear-end.html
What year is your Fatboy?
2003 Fatboy rear fender exact same size as the Deluxe and Heritage rear
I think they are the same then.
I KNOW for positive, the rear fender trim from a Deluxe will fit the Fatboy rear fender perfectly, you have to drill 3 holes. I did this for a rider so I would think the same for a Heritage rear fender trim.
