Clutch issue I think on breakout
Hey, can use a little help before i start ripping things back apart or doing any type of rework. I installed a new clutch cable on my breakout. I adjusted it to where there is about 1/8 of play in the lever and everything feels good when i squeeze it in. Has good tension and snaps right back when I let off. My issue is, when the bike is off(haven't tried while it is running) and in gear, when i squeeze the clutch in the bike will not roll freely. Feels as if the clutch is still engaged. Now may sound strange but I never tried to roll the bike before in gear with the clutch squeezed and I know some bikes can be harder then others to push while in gear. Any help would be appreciated. Thanks for your time.
Check out these threads. They should help quite a bit.
https://www.hdforums.com/forum/prima...-the-book.html
https://www.hdforums.com/forum/prima...-easy-way.html
