Softail Factory Wide Tire Kit
I think I am going to find a 1" set up, I am going to run 18 x 4.25 rear with a 150. Any tips for removing the primary? I seem to remember using a cut piece of 1 x 2 or maybe it was a steel shim to lock up the primary to crack the nut loose on the front sprocket and basket. Is there any benefit to changing the tooth count? What will a 70t turn as appose to a stock 65T will it even work with a 130 tooth belt or do you need to get something else? I am just asking because I'll be in there.. Not sure I'll do the wheels until next winter since the rubber is good on what I now.
I recently installed my own wide tire kit. It's now a 92" FXSTC with a 150 rear. I used a 16" x 3.5 spoked rim, 1 1/8" narrow pulley, and spaced out the rear pulley 1/4". The stock Bobtail fender fits nicely, I needed a wide tire Belt guard too. The 61Tpulley (sportster) uses a 125, or 126 tooth belt for the Evo Softail. And I stand corrected on the 70T narrow pulley, that Harley made. I found one and have sent it to my powder coater. I know you can get a 200MM tire on if you swap the fender and swingarm. That wasn't an option for me. I wanted to keep the stock Sheetmetal for a factory look.
soldierbot (09-06-2019)
Need pulley alternative
I am looking for an alternative pulley for the one that was in the wide tire kit. That pulley (40391-98) is discontinued. What I need is a 65 tooth, 1 1/8" pulley that will fit a 1997 Flstc Heritage softtail. I am hoping somebody on here has found a solution for an alternative part. Thanks for your time.
sCaryCary
sCaryCary
difference between 97 & 2000&up
Thank you Sir Harley for your input. I'm still trying to find out the difference between a 1997 softail pulley (65 tooth, 1 1/8" wide for the wide tire kit) and a 2000-2006 pulley. I think there was a change in the center hole. 1.96" on a 97 and 2.25" on a 2006-2006. Thank you Sir Harley for your input on the prebious posts.
Well they did change the swingarms/wheels/bearings around then, so that makes sense. Use any Narrow Softail pulley up to 1999. (65T or 70T) Good luck
STOCK PULLEY SIZES AND BELT LENGTHS
Table gives stock pulley sizes and belt length for European models. Check OEM parts catalog for non-European models.
Model Year Front Pulley Rear Pulley Belt Width Belt Length
XL883 1993-2003 27T 61T 1 1/8" 128T
XL883 2004-2006 28T 68T 1 1/8" 136T
XL883 2007-2010 28T 68T 1" 136T
XL883 2011 to present, USA models 29T 68T 1" 137T
XL883 2011-2012, International Export Models 29T 68T 1" 137T
XL883 2013 to present, International Export Models 30T 68T 1" 137T
XL1200 1991-1994, USA Models 29T 61T 1 1/8" 128T
XL1200 1991-1994, HDI International Export 29T 55T 1 1/8" 125T
XL1200 1995-2003 29T 61T 1 1/8" 128T
XL1200 2004-2006, USA Models 29T 68T 1 1/8" 137T
XL1200 2004-2006, HDI International Export 30T 68T 1 1/8" 137T
XL1200 2007-2010 30T 68T 1" 137T
XL1200 2011 to present, USA models 29T 68T 1" 137T
XL1200 2011 to present, HDI International Export 30T 68T 1" 137T
XR1200 2008-2010 28T 68T 1" 137T
XR 1200 X 2009-2013 28T 68T 1" 137T
V-Rod 2002-2006 30T 72T 1 3/8" 150T
V-Rod 2007 to present 30T 72T 28mm 152T
Dyna 1991-1994, USA Models 32T 70T 1 1/2" 133T
Dyna 1991-1994, HDI International Export 32T 61T 1 1/2" 128T
Dyna 1995-1999 32T 70T 1 1/2" 133T
Dyna 2000-2005 32T 70T 1 1/8" 133T
Dyna 2006 32T 70T 1 1/8" 133T
Dyna 2007 to present 32T 66T 1" 131T
Touring 1984-1986 32T 70T 1 1/2" 136T
Touring 1987-1994, USA models 32T 70T 1 1/2" 136T
Touring 1987-1994, HDI International Export 32T 61T 1 1/2" 132T
Touring 1995-1996 32T 70T 1 1/2" 136T
Touring 1997-2003 32T 70T 1 1/2" 139T
Touring 2004-2006 32T 70T 1 1/8" 139T
Touring 2007-2008 32T 66T 1" 137T
Touring 2009 to present 32T 68T 1" 140T
FXR 1984-1986 32T 70T 1 1/2" 136T
FXR 1987-1994, USA models 32T 70T 1 1/2" 136T
FXR 1987-1994, HDI International Export 32T 61T 1 1/2" 132T
Softail 1984-1986 30T 70T 1 1/2" 132T
Softail 1987-1990, USA models 32T 70T 1 1/2" 132T
Softail 1987-1990, HDI International Export 32T 61T 1 1/2" 127T
Softail 1991-1992, USA models 32T 70T 1 1/2" 132T
Softail 1991-1992, HDI International Export 32T 61T 1 1/2" 127T
Softail 1993 32T 61T 1 1/2" 128T
Softail 1994, USA models 32T 70T 1 1/2" 132T
Softail 1994, HDI International Export 32T 61T 1 1/2" 128T
Softail 1995-1999 32T 65T 1 1/2" 130T
Softail 2000-2005 32T 70T 1 1/8" 135T
Softail 2006 FLST, FLSTC, FLSTF, FLSTN, FLSTSC, FXSTD 32T 70T 1 1/8" 135T
Softail 2006 FXST, FXSTS, FXSTB 32T 70T 20mm 135T
Softail 2007 to present FLSTC, FLSTSC, FXSTD, FLSTN 32T 66T 1" 133T
Softail 2007 to present FLSTF, FXST, FXSTB, FXSTC 32T 66T 20mm 133T
Softail 2008-2011 FLSTSB 32T 66T 20mm 133T
Softail 2008-2011 FXCW, FXCWC 32T 66T 1" 133T
Softail 2012 to present, all except FXSB 32T 66T 24mm 133T
Softail 2013 to present FXSB 32T 66T 24mm 133T
Last edited by SirHarley; 08-24-2021 at 10:32 AM. Reason: addendum correction pictures
