2015 Slim 6.20 volts after 2 weeks?
Old 01-10-2016 | 08:31 PM
packrat56's Avatar
packrat56
Default 2015 Slim 6.20 volts after 2 weeks?
She sat for a few weeks, i rode her today.. Started normally, then I stopped at a brothers place for an hour and she would not start, all the indicator lights just blinked on and off randomly. I coasted home, luckily it was 90% downhill.
Battery reads 6.20v.. It was on a tender for a few weeks...
WTF?
Anyone?
Old 01-10-2016 | 09:38 PM
Krustee's Avatar
Krustee
Forget your fob?
Dan
Old 01-10-2016 | 09:53 PM
SLV's Avatar
SLV
Loose battery connections or ground connection.
This is the most common cause of this issue.
Old 01-10-2016 | 11:14 PM
packrat56's Avatar
packrat56
Huh...
Everything I can access seems as it should be...
Battery dropped to 5.6 now.. No lights on the dash actually work at all now..
Old 01-10-2016 | 11:24 PM
IdahoHacker's Avatar
IdahoHacker
It wouldn't have started at all this morning if the battery was that low, and if it's dropping that fast now, something is draining it. Something is on, or you've got a short somewhere, I'd guess.
Old 01-10-2016 | 11:28 PM
packrat56's Avatar
packrat56
It was performing normally this morning.
Old 01-10-2016 | 11:40 PM
IdahoHacker
Then the battery was fine this morning.
Have you checked both battery connections?
Old 01-11-2016 | 01:19 AM
gusotto's Avatar
gusotto
Should be covered with warranty.
Old 01-11-2016 | 07:21 AM
captainron62's Avatar
captainron62
Take the battery back to your dealer. They should have a really good battery tester that will spit out a report and tell you if the battery needs warranted or not.
flash0077
06-21-2016 09:37 AM
bocody
03-09-2015 10:43 AM
Lockshow
08-11-2013 11:24 PM
hyfly1
08-28-2012 02:40 PM
lovethemhogs
Ironhead
09-18-2008 12:42 AM
Quick Reply: 2015 Slim 6.20 volts after 2 weeks?
