Oil Change Theory
Oil Change Theory
So since its recommended to check the oil level within 5 minutes of running the bike, it stands to reason that shortly after shutdown the oil level in the tank is higher. Which would also imply that after letting it sit for a while, some oil seeps back down into the crankcase lowering the level in the tank. When you guys drain the tank for an oil change, do you follow this same logic by letting it run for a while and draining fairly quickly after shutdown to get as much as possible out of the tank drain? ThnKs guys.
Scavenge Oil change
A complete oil change in a dry sump engine takes a bit of extra work, but I think it is fun, and I get 30oz of dirty oil out of my engine AFTER draining the oil from the plug.
I think my oil LOOKS cleaner on the dip stick for many more miles using this method, but for some reason this total oil change (scavenge method) remains controversial. If done correctly there is no way you could harm the engine. If you watch the vid, it is OBVIOUS when clean oil enters the clear exit hose, and it is time to stop the engine.
Steve
https://www.hdforums.com/forum/softa...ls-needed.html
Steve
