Nacelle and passing lamps
RE: Nacelle and passing lamps
Yes you need to drill a hole for the switch. I just taped both sides with masking tape, started with a small pilot hole and finish with a new sharp bit. It did not damage the chrome at all. If you don't want to drill it you could move the switch to the handlebars by using the following:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Get the housing and the on/off switch
I was going to do this but running internal wiring would require drilling holes fromt the switch housing to the accessory housing.
V/r
V/r
