2011 Fatboy Lo Load Equalizer
I installed the alloy art led blinkers on the front and the custom dynamics integrated taillight on the back. I am getting the usual fast blink on the dash and now I'm getting some weird flickering on the taillight. I called custom dynamics and asked about their load equalizer and they told me I didn't need one and sent me an email with how to hack the CANBUS system. I appreciated that they did that bc it would save me $$, but I have tried and tried their hack and just cannot get it to work. Has anyone here with a '11 softail been able to override the system using a hack or will I need an equalizer after all?
2011 Fatboy Load Equilizer
I also have a 2011 Fatboy, I have LED's and the Red Security/Electrical Fault Light stays on, I have a Load Equalizer, took it to Local Harley Dealer, their answer was that the 2011 was the first year with that ECU, and that it was so sensitive, that it picks up the LED's as low volt short in system. Supposedly 2012 they changed and it's not a problem. But I still have light on in dash.
I changed the Load Eq. and had no effect...F.Y.I.
As for my '14, I had installed the HD run/brake/turn adapter prior to ordering the rear LED. Have to use CD's adapter for the rear LEDS, they will not work with the HD adapter.
I appreciate the replies, I forgot I had another thread in the electrical forum as well. Turns out the problem I had was that my tire rubbed through part of the wiring under the rear fender, causing the open output codes and the flickering. Once the wiring was rebuilt the bike is operating as expected, normal blinker rate but rapid flashes on the dash indicator.
If you check your codes, you will find that the system thinks your front bulbs are burnt out. That is why the dash blinks fast. The bulbs still blink at a normal rate though. The fast blink drove me crazy so I put normal bulbs back in the front.
The system seems to only care about the fronts being LED. My system is working fine with LED rear and normal front.
On my 2014 Breakout I installed front led turn signals without load equalizers and had turn signals and dash light fast blinking. Read somewhere to try and leave the turn signals blinking for some minutes, this way the ECM would "learn" to recognize the new led turn signals. Told my dealer to try this "procedure" and they said it was BS...guess what? They left turn signals blinking for about 15 minutes and the DCT code disappeared, turn signals blink normally as well as dash light. They couldn't believe to their eyes.
Same thing with a friend of mine on a 2015 Touring model.
Don't ask me how it works and if this strange procedure works for all led lights or models because I have no idea. Just thought my own experience could be of help.
Cycle your four-ways on for a minute or two, this is supposed to "re-sync" the flash rate. This has worked for me although sometimes I'd have to run the four-ways for longer than two minutes, and for some reason the "fast flash" always seems to return randomly...
sobr0716
04-16-2012 09:30 AM
Wabbit
02-04-2012 07:40 PM
