Original oil or Syntheic
Old 05-04-2007, 10:32 PM
weasel's Avatar
weasel
weasel is offline
Default Original oil or Syntheic
I will be taking my standard in for its 1000 miles service. Which oil should I have them put in and why? If i change to synthetic what will it do the the warranty, if anything.
Old 05-04-2007, 10:53 PM
99superglide's Avatar
99superglide
99superglide is offline
Default RE: Original oil or Syntheic
I use Mobil 1 15w50 extended service full synthetic in my bike though some may disagree.
Most on here would recomend Mobil 1 20w50 full syn for V-twins or Amsoil 20w50 full syn for the motor. HD charges the same price for their Syn3 as the above 20w50 but its not really a full syn.
Mobil 1 75/90 full syn in the tranny. Much smoother shifting and easier finding neutral.
You may get many different suggestions for the primary fluid but I haven't experienced any noticable difference in any thing I've tried that's suitable for the appliacation.
Old 05-04-2007, 10:57 PM
Clammy's Avatar
Clammy
Clammy is offline
Received 1,865 Likes on 808 Posts
I use Amsoil 20W50 in the engine and primary, and Amsoil Severe Gear 75W90 gear oil in the tranny. It won't affect your warrantee since it exceeds the OEM specifications.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old 05-04-2007, 11:59 PM
dg7080's Avatar
dg7080
dg7080 is offline
What Clammy said.
Old 05-05-2007, 12:34 AM
bobros's Avatar
bobros
bobros is offline
What dg7080 said.
Old 05-05-2007, 01:02 AM
SPRINGER's Avatar
SPRINGER
SPRINGER is offline
Received 3,270 Likes on 1,976 Posts
I was talking to the mechanic where I bought my bike and he said that I could go longer between oil changes if I switched to synthetic. He suggested that if I used regular oil I should change every 2500 miles. He said that if I switched to synthetic that I could go 5000 miles between oil changes. Since I go in every 5000 miles for warranty work, that sounded great to me. I also asked him this, if anything goes wrong while using the synthetic, will it be covered under warranty and he said yes. They have bent over backwards to make me happy in the past and I saw no reason to disbelieve him. I changed based on his recommendations. Each to his/her own, but I've been happy so far. Good luck
Old 05-05-2007, 02:41 AM
pococj's Avatar
pococj
pococj is offline
Received 1,296 Likes on 483 Posts
Why not drop down to the oil related forum and start reading. But start in the top section first.
Old 05-05-2007, 08:24 AM
AceHog's Avatar
AceHog
AceHog is offline
Don't waste your money.
Old 05-05-2007, 09:24 AM
bobros's Avatar
bobros
bobros is offline
ORIGINAL: AceHog
Are you saying synthetic is a waste of money or changing oil is a waste of money?
Old 05-05-2007, 10:12 AM
AceHog's Avatar
AceHog
AceHog is offline
Are synthetic oils better, yes. Is it worth it, no.
Quick Reply: Original oil or Syntheic
