My Mods Thread - 2016 Softail Slim S
#91
Installed the Wards Werks Cooling Fans - take offs from my RK CVO... great fans to cool down the engine.
Also working on the front wheel... because this has ABS...and the 48 did not, I am going to have to remove the parts from the Slim wheel to transfer to the Fat Bob wheel... some tinkering required...
But I like how it looks!!
#93
I will also need a different spacer on the right side... hummmm... I will either have to order one in the right width or modify one that I have, to add to the stock unit. I much prefer to have just one in the right width and not add... will order one once I have the correct dimensions for it.
#94
#95
Both the Slim and the Fat Bob use the same setup and same part numbers for both parts. Inner bearing size is 25 mm.
I was able to remove the bearing (Part No. 9252) from the Slim front wheel and installed it on the Fat Bob wheel. That part went fine.
Now I need a 25 mm x 3/4" spacer for the right side of the wheel...
My concern is more with the way the Slim front wheel is when compared to the Fat Bob... the FB front wheel hub is symmetrical, where the the Slim has one side wider than the other...
Once I get the correct spacer I will know if all this works...
#97
The front one is where the work is...
#98
A few photos removing the ABS wheel bearing. Tool works great! First time I use it to remove the bearings... and I did practice a lot since I forgot the inside spacer when installing back on the FB wheel, lol!!!
Also, I ordered a few different size spacers from eBay... should be here next week. I hope that I do not have to take the front wheel to a machine shop to modify for fitment..
Got to go... food is ready and I see a few beers with my name on them! Good night!
#99
#100
options
Bike looks good like you a picked up a S model on Saturday , right now not game to change anything , sorry It is a lie got the S/E cannon with caps he he he love . post picture soon like you I have switchback wheels sitting right there saying swap me swap me
Ride safe Dynaunder
