Help! Need New rear tire on faboy cause I only get 5k on stock ones
Old 05-11-2007 | 09:32 AM
XTrooper3936's Avatar
XTrooper3936
Default RE: Help! Need New rear tire on faboy cause I only get 5k on stock ones
Some of you fellas are assuming that every Dunlop tire is identical to the next and that they all use the same tire compound. They don't.
Just because you got 10K+ miles from the Dunlop rear tire on your bike doesn't mean "there's something wrong" if someone else gets 5K-6K from the rear tire on theirs. Every tire manufacturer builds tires for a full range of uses, with hard to soft tire compounds, and having differing mileage expectations. For instance, touring bikes, which are generally expected to be ridden more and farther than other types, may be fitted with harder compound, longer mileage tires while sport bikes would likely be mounted with soft compound, maximum traction/low mileage tires. Cruisers may leave the factory with something in between.
On a personal note, I bought a 2007 Fatty new last October after not having ridden a bike in nearly 30 years. Since then I've put ~2500 miles on the bike, all solo miles, and all babied and, although I can't estimate how much life is left in it, my big 200mm rear tire shows definite signs of wear. Also, fwiw, I was told by my dealer at the time of purchase that I should expect to get approximately 5K from my factory tires.
Old 05-11-2007 | 11:13 AM
Tin Gizel's Avatar
Tin Gizel
I got 7200 on my FB right now. Original rear tire. I do a bunch of baby burnouts. Still GTG on my rear tire. I was expecting it to be bald from what i read, but it's fine for now.
Old 05-11-2007 | 12:04 PM
tail11's Avatar
tail11
I check air pressure once a week and I ride solo. I change out my rear tire every 5k, and it still has sometread left. I will not run them bald.I've switched to Pirelli tires.
[IMG]local://upfiles/13603/A0875D06D8FF41C58B0C69A5D585EABD.jpg[/IMG]
Old 05-11-2007 | 12:53 PM
Mikey 1450's Avatar
Mikey 1450
I would guess your riding style and not using your front brake.
Old 05-11-2007 | 08:55 PM
moggsy's Avatar
moggsy
I run the HD whitewall Dunlop 150's i think on my heritage and i have 12k kms and still got heaps left.5k seems really low to me.Most of my riding is solo with the odd long trip.
CookUltraClassic
07-03-2023 11:29 PM
dubepj
07-15-2019 07:13 AM
jory434
12-05-2012 11:01 AM
2007fxdc
03-22-2008 10:42 AM
Edelmon
03-13-2007 11:05 AM
Quick Reply: Help! Need New rear tire on faboy cause I only get 5k on stock ones
