Should I cut my new Longride widshield?
I have a 15 Slim I got a detachable windshield. I got a HD detachable windshield. I then got a 16 Long Ride recurve windshield. I am around 5'7. The top of the windshield I in my line of site. I am not to sure how small of a shield I should have? Do I cut my Long Ride shield? I know it will eliminate the recurve on the shield. Or are there better options? I already installed the shield so I can't return it.
I'm the same height as you. Have the 15" LRS. While I would still like it about an inch shorter, I've gotten used to it now. Only time it's really line of sight is in hills. Flat roads and freeways I see over it. I could see where 16" would be problematic. Sell it and get a 15".
Same setup too, H-D quick-detach with a 16" LRS Recurve screen.
I had that issue with the stock 18" shield - right in my line of sight.
FWIW, I have the quick-detach model that's used for bikes WITH auxiliary lights.
I wonder if that makes any slight difference, mounting or height-wise...?
