S-Series - Home Base
Old 01-17-2016, 10:07 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
Paul, have one made to hold 12 gauge shot gun shells
  #792
Old 01-17-2016, 10:25 AM
paullavery's Avatar
paullavery
paullavery is offline
Good idea.
  #793
Old 01-17-2016, 11:13 AM
WKNDS's Avatar
WKNDS
WKNDS is offline
Received 1,360 Likes on 986 Posts
Originally Posted by paullavery
...snip...
I'm having issues mounting the WLA style seat & have posted the issues in a new thread, but was wondering those that have fitted the piston kit, is it ok to re-locate the earths to the bolt at the back of the piston ? (The one with the Phillips style bolt).
...snip...
I'm not sure you'd get a good ground there. Definately remove paint to get a good
connection. All you can do it try. I used the two bolts going into the frame.
One of them is a long "all thread" for lack of a better explaination, that I used
to secure the top of the cover. Here's some pics.
hope this helps,
T.
  #794
Old 01-17-2016, 12:10 PM
paullavery's Avatar
paullavery
WKNDS thanks for the pics, I did think of using the 2 front bolts as you did, however using the rear seems to work ok at the moment.
I'm going to try & use the original plastic seat pan but if it doesn't work out I may just go for the same as you with the lower cover & the fls ecm cover.
Already stripped the seat to see what the pan looks like & will dry fit it to see how it looks before cutting it up.
  #795
Old 01-17-2016, 02:15 PM
splattttttt
great idea using the stock seat pan. hope it works!
  #796
Old 01-17-2016, 07:54 PM
SLV's Avatar
SLV
SLV is offline
It wouldn't have dawned me to try that. I hope it works out
  #797
Old 01-17-2016, 10:16 PM
HenryT's Avatar
HenryT
HenryT is offline
hope this helps,
T.
Looks like an option.....have to say though it looks like a mountain of plastic....would like to see pics with the seat installed.
  #798
Old 01-18-2016, 05:31 AM
WKNDS's Avatar
WKNDS
WKNDS is offline
Hehh - guess you must've missed it - its been posted in this thread already.
hth,
T.
  #799
Old 01-18-2016, 08:55 AM
BBSHK's Avatar
BBSHK
BBSHK is offline
Post a pic when it's installed. I see it's matte black, couldn't find a gloss black version.
  #800
Old 01-18-2016, 09:03 AM
Jetfever's Avatar
Jetfever
Jetfever is offline
Default Relocate your ECM
I agree about the "mountain of plastic"...
I can't wait until I see a pogo seat set up with a cover like I made:
Quick Reply: S-Series - Home Base
