S-Series - Home Base
#1282
Originally Posted by sevebou63
I'm assuming that question was directed at me?? They are Viking bags I bought used off of eBay for 100.00. I modified them to sit lower. Problem with the softails IMO is the bags sit too high to dodge the axle nuts. Which to me looks like ***. So I made my own fixed bag mounts and dropped them a good 5 inches. Had to modify left bag to clear axle nut. Took a chunk out of the bag to make a cavity and boxed up the hole with hard plastic lining. Misses the nut and looks much more balanced.
#1283
Well for those looking for more comfort on their slim S, I can now recommend the Mustang solo vintage seat with back rest. The foam is just right. Not too soft, and not too hard, like my Corbin's. The back rest is amazing. It takes so much stress away from your body during acceleration. You just lean against the back rest, and let it rip! The back rest is height adjustable, and can be tilted to suit your back, lean angle. I also had the windshield chrome parts powder coated black. I also had the shifter, and arm coated, and the rear brake pedal and license plate frame. Pics to follow.
#1285
Love the look of your pipes. What model are those...or even better a part number. I have to order from USA so want to make sure I get the correct one. Thanks in advance. Cheers, Greg
#1287
Same issue here... did not notice until arriving from a ride and seeing that my headlight had rotated... I was going to try placing a rubber gasket inside the ring but using the stock one and just painting it black looks like an easier approach.
#1288
My '16 FLSTFBS with a few bolt on mods. This is my 4th try (and probably last) to post this. The first three with embedded pics failed.
Cobra RPT slip ons
SEPST
Passenger mini footboards
Fat Boy Pillion
Med-Low sissy bar with wide backrest and sport rack
Get-a-grip hand grips
Softbrake lowered brake arm
Softbrake shift arms, linkage arm, and linkage
Daymaker Projector (black)
HD Layback LED tail light
Custom Dynamics Dynamic Ringz front turn signals
Kuryakyn LED rear turn signal bulbs
HD Layback plate mount
Dead Creek Bobber bracket with Viking swingarm bag
Cobra RPT slip ons
SEPST
Fat Boy Pillion
