What are you doing for a brake light switch? I bought one from Goodridge but I am stumped on how to install it.
Let me know about the brake light switch man.
The Goodridge Brake light pressure switch wiring is almost a direct swap with the HD version, you just need to replace the ends of the leads with 2 larger spade connectors like so;
New banjo's fitted to rear brake caliper and rear brake master cylinder.
Mocked up a piece of tubing to get the correct length of brake hose between caliper and master cylinder.
Goodridge instruct that the measurement should be taken from the centre line of each banjo, my setup measures 540 mm.
Glad to hear you're moving forward with the project. Mine has completely stalled. Too cold here to be outside in the garage working on the bike.
The kick stand is a niece piece, it's amazing that they don't realize they are sending out the incorrect set screw with it hahaha.
Thank you for the info on the brake light switch. I haven't looked at my bike in a long time so I forget what the connector on the bike's wiring harness looks like. I'm sure that using those same spade connectors in your picture would work for my setup.
