Power Vision autotune #7... wow
I had a "wow" moment on my ride into work this morning. I was running autotune for a seventh time, and I think it was when I was riding up an interchange ramp in 6th, close to the top where it turns, and I realized it was pulling just fine at low RPM in 6th, where I'd always need to downshift... coasting uphill.
But it was more than that. Every gear was smooth in a way that I've never experienced before. The engine just sounded different - like deeper and confident (?). And I was marveling at how I could close the throttle, and there was no popping at all.
I know this is kind of a "nothing" thread - probably nothing new to anyone here with experience with these things, but I was moved to post about it.
I found "corrections" mode on the grid this morning too, at a stoplight... had not seen that yet. I'd been looking at the "hits" screen. And at this point, most/all of my numbers are +/-1, or pretty small. So I'm guessing maybe it is getting close to where I probably can just go with what I've got.
Anyway - just amazing. It's like a whole new bike. I should have gotten the Power Vision before doing any other performance mods on the bike... just wasn't educated enough at the time. Live and learn.
Similar experience here...
Been tuning a cam/2-1 change with an FP3 - base map was a country mile away from being useful so tweaked and developed my own and several autotunes later, last time out the bike was just singing - really strong, pulls from almost nothing, and the first time I have ever rev'd to 5k - only because it was sooo smooth I never even noticed.
Still a wee bit to do up top now that I know it revs nicely up there but it's great when a plan comes together
The map that FuelMoto gave me actually didn't work. The PV told me it was incompatible. So, I extracted the existing tune off the ECU into a pvt to compare, and they were totally different. The one off my bike was TPS (throttle position sensor?) based, and the one FuleMoto gave me was not.
I did a little poking around on their site, and it looks like maybe Jamie gave me a map that was intended for touring bikes and not the Softail. I tried merging the map they gave me with my base map off the bike, and I thought that was working (and replied to Jamie that I thought I'd figured it out), but it wasn't - since the maps were not compatible.
So... I ended up going to the Dynojet site, and downloading their SE Air/Bassani slip-ons map. I have an SE Ventilator and Rush 1.75" slip-ons, so that looked like it would probably be the closest - and used that as my starting point.
Do you have to switch back to the stock sensors after you're done tuning? I figured the wide band sensors would be like a permanent replacement (?).
