dual fish tails
RE: dual fish tails
I got the True Duals for 1986-2006 models for Softails through my Harley Dealer. They are the True Duals Fishtails w/short mufflers.They have the heat shields. The price was around 600.00 after taxes. J&P has them listed in their cat., page 198. at the bottom.Hope this helps. I got my Harley dealer to install them. I already had the stage one and was told this is all I needed. So far, so good.
RE: dual fish tails
Cheapest way to do this would probably be the Samson Fishtail Trual Duals. I got mine from I believe it was Direct Parts or something like that out of Arizona, good guys to work with. I had the Stage 1 download at the dealership and they work pretty good. I have had this setup for a year right now. If you want to spend a little more the V&H fishtails look real sharp and no doubt good quality. Good luck,
RE: dual fish tails
I have an '07 Springer Classic. Before rolling it out of the dealership I wanted the duals installed. Problem is that they didn't make the true duals for it yet. I settled for the vance and hines fishtails. I really like them as they have a great sound, and lookgood too! I personally don't like the way some stick out past the rear fender like a foot or so. I don't have that problem w/ the V&Hs-they end flush w/ the fender.
RE: dual fish tails
If you ever plan on building the engine, I would recommend you take a look at the VH fishtails over the Samsons. I have been told by more than one engine builder the Samsons will hurt the performance on a built engine. I don't know about the VH, but guys on this forum say they are not hurting performance on their bikes. If you only plan on keeping the engine stock, either should be ok...go with the one you like the looks of the best.
For price, its hard to beat American Classic Cycles. Putting pipes on is an easy do it yourself job along with the SE aircleaner. If you have a laptop, you should consider buying the Race Tuner and programming the ECM with the Stage 1 download yourself. Its easy to do and with a little reading and practice, you can fix some of the inherent problems with the Harley Stage 1 download. It is notorious for still being lean and this is easily corrected with slight adjustments in the A/F table. Other things like popping on decel can be fixed easily too.
Good luck!
Good luck!
