Tricky air suspension
Thinking of either putting on a raked fatboy front end or air ride. Tricky air ride said they would build me a complete front air ride kit for my night train. I think the air ride is such an awesome design just kind of wanting to hear your thoughts on the the front air ride good or bad or if I should just stick with a raked fatboy front end. I'm pretty torn between the two and need some input.
That was one of the questions I asked them. I told them this is not a show bike it will not be tailored everywhere and I want it to be reliable. They told me that is very reliable to take on long rides. Just a little skeptical because I've never seen this done on anything other then on show bikes.
I have some questions that you might not have thought about.
Where would the compressor go? Unless you plan on making a cubbyhole in the gas tank, I don't see any clean mounting points. (This assumes that you already have a Shotgun Shock or other air ride system with the compressor mounted behind the transmission.)
What happens if the air pressure is not equal on both sides? Would it effect handling in a negative way?
If one was to hit a pot hole big enough to damage the rim, would the air suspension survive from the impact like the conventional suspension?
I didn't ask if it had a damping valve. You are right though, there is some reliability issues with front air ride. After giving it some thought I think I'm going to stay away from front air ride and have something a little more practical.
