Indroducing my new breakout
Old 05-20-2016 | 08:42 AM
matte's Avatar
matte
After a crash course in soldering and a long painful week of a disassembled bike, the truwrapz and the fender light are installed and finally working appropriately. Pics will come as soon as the bike is completely together. Wondering of anyone knows a good LED bright bulb that I could use as the truwrapz DRLs make the yellow hue of the stock bulb painfully obvious. I can't spend the loot on a daymaker or a 200 dollar knockoff. Just want a white bright light to throw in there until I decide to pull the trigger on something more spendy. Suggestions?
  #52
Old 05-20-2016 | 10:28 AM
Drodrigueznyc's Avatar
Drodrigueznyc
I purchased the PIAA H4 extreme white, anti-vibration bulb for $35.00. made a huge difference. In my opinion, if they last, I won't be swapping to a daymaker. the brightness also matches the white LED turn signals from Custom Dynamics (which turn yellow when activated)
try that first before you spend real money on a headlight.
btw, welcome to the club.
  #53
Old 05-20-2016 | 09:19 PM
Duke 13's Avatar
Duke 13
Carlini bag drag bars. They pull back like beach bars, but a more aggressive angle.
Matte,
I was looking at the Carlini bars. Are yours 1.50 diameter? Also did you use the stock switch housings?
  #54
Old 05-20-2016 | 10:18 PM
Zakk13's Avatar
Zakk13
Very nice..
  #55
Old 05-21-2016 | 06:14 AM
matte's Avatar
matte
Originally Posted by Duke 13
Matte,
I went with the 1.5. But in hind sight I should have gone 1.25 to give my hand grips more play. Where I have my bars, they don't really fall into the indent for the brake oil reservoir.
  #56
Old 05-21-2016 | 12:11 PM
Duke 13's Avatar
Duke 13
What diameter is the riser clamping area and how did you get the switch housings to fit the 1.50 inch bars?
  #57
Old 05-21-2016 | 03:45 PM
matte's Avatar
matte
It rests a little outside the flat part of the bar. Just need to tighten it so it doesn't slip. The clamp area is 1 inch. There are some step ups you can buy. But I just bought a black 1 inch id/1.25" od black rubber hose, cut it to size, cut a slit down one side and used that. Now I have rubber mount handlebars
  #58
Old 05-21-2016 | 04:36 PM
Duke 13's Avatar
Duke 13
Did you have to do any new lines? Also I didn't understand how the switch housings fit a 1.50 diameter bar. Can you elaborate on it?
  #59
Old 05-21-2016 | 04:37 PM
Duke 13's Avatar
Duke 13
Also, did you get your taillight installed and working?
  #60
Old 05-21-2016 | 05:44 PM
matte's Avatar
matte
The end of the bars fit regular switch housings. The 1.5mm drops to the right size right before there the bar/housing starts. For the right side, there is a flat area where the oil reservoir sits in which under most conditions is fine. But I like my bike bars a little lower...so mine sits half in that flat area and the other half on the edge of it. Still works fine. Just need to play around with it.
Quick Reply: Indroducing my new breakout
