My clutch cable is crazy
So I've been running my clutch cable unattached to the frame down tube since I installed my clip on handle bars.
Today I decided to try to clamp it to the frame by using a zip tie that came with the clutch cable when I bought it. After I had the clutch cable tied to the frame I noticed that the clutch lever now had a lot of slack in it that wasn't there before.
What's that all about ?
I ended up taking the zip tie off and leaving the cable hang free. Then I noticed that the play in the lever was still there and the free play where the cable goes into the clutch housing was more than before I attached the clutch cave to the frame.
I had to re-adjust the cable and take the free play out of it. Now that I did that the clutch engages a lot later than it used to. Before all this the clutch would engage as soon as I would let the lever out, now I have to let the lever out half way to get the clutch to engage.
I'm scratching my head trying to figure out what that was about though. Any one have any idea?
But what about the change in the position of the lever where the clutch engages.
Received 5,583 Likes
