A little help?
Old 09-20-2005, 09:08 PM
softtail3005's Avatar
softtail3005
softtail3005 is offline
Former Sponsor
Default RE: A little help?
You might also want to take a look at the EVO thread.
Old 08-22-2010, 07:16 PM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
Originally Posted by HDF Tech
For the most part the evo's had some problems with the cylinder base gaskets weeping or even breaking on ocasion. They were like a thin paper gasket as compared to the "O" rings of the twin cams. The rocker box gaskets were a weak point also, other than that , they were great motors.Clean out the lifter screen which is under the big screw head over the oil pump. They tend to accumulate sludge in there which restricts oil to the upper end.
and CHANGE any o-rings you run across every time , like on that screen and oil drain plug, I found out the hard way they will leak
champ198
11-05-2018 03:31 PM
metromix
02-22-2012 08:15 PM
rudy4536
10-03-2010 10:07 PM
eliems
06-03-2006 11:04 AM
CANTDR55
General Topics/Tech Tips
20
11-22-2004 09:37 PM
Quick Reply: A little help?
