Throttle Cables Reversed
I have a 1991 FXSTS and I'm in the process of replacing the stock CV carb with a new S&S Super E carb. After installing the new S&S manifold I attached the carb. After attaching the throttle cables to the throttle system and housing bracket, I twisted the throttle back to make sure it was on correctly and noticed the cables were loosening when I pulled back on the throttle. Doesn't seem right....
After thinking to myself, I thought well why not just switch the cables on the grip and throttle housing. Well the threaded retainer on each cable has a different size. The throttle cable hole is larger than the idle cable. That didn't help.
If I buy the S&S throttle cables for my particular year and make of Harley, will that solve my problem? Will it still be reversed?
Any help would be greatly appreciated!
adjust the throttle cable first. Throttle cable should be most forward at the throttle. Adjust that cable till, at full throttle, it is at the throttle stop.
Then adjust idle (rearmost) cable till you have minimal freeplay
Beyond this get someone that knows what they are doing, your life will depend on it
I'm thinking since the CV carb had a reversed housing bracket, installing the new S&S would reverse the cable guide on the carburetor. Maybe I need to call S&S and explain my situation but I thought i'd give it a try on here and see if anyone ran into the same problem.
JohnnyBravo
12-11-2010 04:27 PM
