Is This Possible?
RE: Is This Possible?
Regardless of whether you have a carb or fuel injection, a new exhaust will typically improve breathing, moving more air through the combustion chamber. In order to get some of the benefit, you should also put a better air cleaner (but don't go crazy as the heads in the motor are really air flow limited). With or without the breather, the exhaust moving more air will typically cause your bike to run lean. You should rejet your carb or remap your fuel injection.
I don't think if you are just doing stage 1 (pipes and breather) that you need to do the fuel pak - the remap on the fuel injection, particularly for popular pipes like the V&H, are typically very good.
Dyna346
07-26-2012 07:38 AM
Irontater
07-28-2011 11:10 AM
