FIRST PICTURES VANCE & HINES TRUE DUELS
Here are the first pictures of my deluxe with the Vance and hines true duels I will do a better job when i have time. First off the myth about loosing 20 to 25 horse power with the duels is a crock. My bike pulls just as good as before if not better i feel no loss of power at all. now i had a standard Harley down load for a 95 build with cams and heads big bore kit when i started the change to the duels. when finished it still runs perfect no popping no hesitation and it idles great no power commander no race tuner or fuel pack no dyno how sweet it is do not have to put out another seven or eight hundred. plus factors with the new set up back wheel is more visible the chrome caliber now shows right side foot rest now has more room nothing behind it to hit. tire is easier to clean and the exhaust is now not hitting the white wall. installed the quite baffles not that quite nice sound totally happy with the set up and look fishtails on back order.
picture links below
http://www.nikonf8.com/pipes.jpg
http://www.nikonf8.com/pipes2.jpg
http://www.nikonf8.com/pipes3.jpg
picture links below
RE: FIRST PICTURES VANCE & HINES TRUE DUELS
Nikon,
Looks good and glad to hear your seat of the pants tells you the power didn't change.
Losing power with fishtail duals however, is not a myth or a crock. Others have not been as fortunate as you even though they have spent hundreds on dyno tuning. Apparently, Vance and Hines duals are better performers than Samsons and the standard HD download is better than tuning on a dyno.
When I had my motor built it was all Harley I believe it was a stage four package all elements were a package no deviation I would think this package and map were married by way of testing. When the bike was finished I was only running cycle shack slip ons which were rated very highly on the performance charts. The bike ran good no hesitation no popping no problems at all. I was hoping that this exhaust change would not require a new map or commander or tuner. Today I got a chance to really evaluated it and the veridic is it actually runs a little better and power wise I feel no loss at all. I feel pretty lucky that it runs so good with out all the added expense of the dyno and adjusting equipment pc111 or tuner. I spent $719.00 for the complete system including the quite baffles and fishtails shipping included. Most guys who start stock have to go for 1500 or better depending on if they are doing the wrenching them self if not closer to $2000. If you buy the pipes through the dealer with baffles and tails your looking at about 900 dollars then with a stage one and tuner and dyno about another 800 dollars then ad your labor for installing the tuner and pipes stage one about 5 or 6 hours = another $375.00 wow big bucks
