New Exhaust Checklist
So, I've got a 2014 Deluxe, and I'm wanting to get a dual exhaust with fishtails out the back. I'm open to any manufacturer, but what I have heard and need to do is if I do a new exhaust, then I need to remap the bike as well? And a new breather too? At least that's what the Harley dealership is telling me.
I want to make sure I have the full scoop on what I need to do besides get the exhaust. Also recommendations on what brands to use for mapping the bike. I'm a set it and forget it type of guy. I don't want to have to tune this thing every time I hop on it.
Any help would be greatly appreciated!
Generally speaking if you're just changing your exhaust you don't need to do a thing.
But once you change out and open up that restricted stock air cleaner, then you'll need a tuner.
You do NOT need to change your air cleaner just because you changed pipes.
That's just the dealer in SELL mode.
That being said, you'll get the most bang for your buck if you DO change the air cleaner as well, and get a PROPER (non-dealer) Stage 1 tune.
After not being happy with my setup (pipes, a/c, dealer "remap") I went with a Vance & Hines FuelPak 3.
It's a whole new bike...
Before
After
As for the tuner. Devin and Kevin(DK) use the Power Vision and are very happy with it! One of the many good things about the Power Vision is it comes delivered to you with a Custom Map, for Your Bike, already installed in it. You can plug it in, load the new tune into your bike, unplug it, and be riding with the New Tune in 5 minutes.
Also, here is a overview of EFI options, this may help you out https://www.hdforums.com/forum/ignit...uning-etc.html
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
As said, you do not need a tuner or have to add upgraded Air intake if you just change the exhaust.
Power vision is a good tuner, I have had it on two bikes so far. It allows you to do more changes to the bike like adding cams.
The V&H FP3 is a good set it and forget it tuner for what you are doing. I have installed it on a few bikes now with no issues. Easy install and easy set up.
I went with V&H. I probably would have gone Sampson if I was going Long out back, but the length on the VH Duals was where I wanted the pipes. Tucked in nicely under the end of the bag. I also like them because the Fishtails are slightly wider.
I have seen both the V&H and the Samsons, hands down the Samsons longtails are better looking, I ordered Samson mini 36" longtails from Phat Performance last week Monday, they have the best priceless anywhere for these pipes. They will be delivered to my door tomorrow .
It all has to do with what your vision is for your look, sound and performance.
I spent a long time searching and looking at pictures and specs of different exhaust on my model.
I went with the Bassani Road Rage 2:1 as it was what I wanted for my Fat Boy Lo vision.
Good luck and post some pictures when you are done.
