Springer Owners-anyone use Wild 1 Chubby Stubby Springer Risers?
Here's the link. I ordered directly from them. They don't maintain a stock of sissy bars. They begin to build it when the order is received.
http://www.ginzchoppers.com
*EDIT* I think I mistook the risers being discussed on this thread for something else I saw that looked like these. I checked these out on the site again and I think I can tell that the threads might in fact be a bolt that feeds through the risers. My guess is that the other risers I was thinking of do the same thing as these and only looked like they were all one piece.
Not actually interested in these risers myself but recently I took a closer look at them while on the site and realized that unlike stock risers that fit over a stud and held down by a lock nut, these risers thread directly to the forks in place of the stud. However, I couldn't tell that the upper riser portion had any way of spinning independent of the lower threaded portion. So my question is, since these replace the stock for studs how do you torque them down to spec while assuring that the riser portion will align properly for the installation of the handle bars?
I just installed these on Sunday and didn't know what you were talking about until I did it myself. The risers do turn a bit when you initially start tightening them down. Tighten some, then place the bars in the grooves to keep them in line, then tighten some more. After a point, they don't twist any more and will stay put while you tighten them the rest of the way. These things are rock solid and feel so much more sturdy than the stock risers. They bite and hold like a pit bull, and are just as solid.
Did they come with good instructions? TOrque spec, etc?
The instructions were very basic and straight-forward. Not nearly as complicated as the stock HD risers. The base of the risers bolt directly onto the fork with a very beefy 1/2" Allen head bolt. There were no torque specs provided, so I used what HD specifies. If they ever loosen up, it's a simple matter to re-tighten them. I doubt that will happen, though. The weather is bad here in Philadelphia, so I took it around the neighborhood a few times and, from that, I didn't feel any additional vibration. For me, I'm really glad I made this switch.
the vibration is not bad at all. IMHO it is the same as stock risers but just WAY more solid felling
One last question. Wild 1 claims there's is a 2" riser. The stockers are roughly 2.75" from the bottom of the lower riser body to the split. So technically, these are shorter than the stock versions?
