The progressive drop in really isn't that bad of an install + its adjustable 0-2 inches + its $93 on ebay. I have it in mine and installed it alone in about two hours.
The Monotubes add a major improvement on hydraulic damping, and for this reason I'd promote it over the "drop in".
to do the mono's do you have to pull the entire front end apart to slide out the fork tubes??? seems like alot more than 2 hours work?
You need to slide the shocks out the triple trees, but don't need to pull the tubes out.
Took me less than two hours, and believe that a novice wrench could do in that time.
