Installing Apes...few questions
Old 12-19-2014 | 09:27 AM
Visago's Avatar
Visago
Thx guys!
Old 12-19-2014 | 09:30 AM
Daddy454's Avatar
Daddy454
Originally Posted by Sgt_Jim
some of those had to be done twice because i was too stupid to remember to put the piece of shrink wrap on the wire before i soldered it. haha.
LOL....this is where I my most practice soldering.
Old 12-19-2014 | 09:39 AM
rockabillygrl's Avatar
rockabillygrl
Hill Country Customs. They build it all for you, plug and play. Waiting on my 14 Burly bars as we speak. Easy peezy, lemon squeezy.
Old 12-19-2014 | 10:06 AM
Misbehaven's Avatar
Misbehaven
For wire extensions I like the ones from http://www.namzcustomcycleproducts.com/ they are 100% plug and play. No having to disconnect wires and pins. just plug them in. Also it is nice with the newer bikes with canbus that the plugs are now small enough to fit through the holes in the handlebars. It really helps to simplify the wiring portion of a bar swap.
Old 12-19-2014 | 11:38 AM
Visago's Avatar
Visago
Cool man thx! I'll look into those.
Old 12-19-2014 | 02:18 PM
kizzletruck's Avatar
kizzletruck
I went with the (black) Burly brand wire extensions and cable kit for my Night Train. Happy I did. It was simple, relatively inexpensive, and the install was easy. If you don't mind a little soldering and heat shrinking, it's not all that bad. The trick to removing the wires from the plugs is to use a bent-back paperclip, and use this as your 'picking' tool to release the clips in the connectors.
Otherwise, for running the wires internally, I just take a piece of string and put a fishing weight on the end to feed it through the bars. Tie it in a circle, and tape the wires to the line and pull them through one by one. Goes pretty quick. On my Deluxe build though, I am going to experiment with different methods on using braided expandable sleeving on each set of wires to give it the nice clean look. Not sure if it will create more problems trying to feed it (I'm sure it will) but the cleanliness will be worth it.
Old 12-20-2014 | 11:41 AM
Visago's Avatar
Visago
Good advice...appreciate it.
kyle0758ff@gmail.com
11-06-2016 11:10 AM
TriggerHappyJack
02-01-2011 01:37 AM
MOSTWANTED
10-11-2008 09:04 AM
will227457
09-02-2008 03:21 PM
jnslim007
05-15-2008 06:29 PM
Quick Reply: Installing Apes...few questions
