Replace air cleaner?
Old 12-13-2014 | 09:10 PM
JonGolden's Avatar
JonGolden
Default Replace air cleaner?
If I just wanted to replace the stock air cleaner, do I have to do anything else with the engine?
Old 12-13-2014 | 09:23 PM
QC's Avatar
QC
Might want to consider getting a fuel manager. Not absolutely necessary, but recommended. FuelMoto would be the place to go.
Old 12-13-2014 | 09:36 PM
streeteagle's Avatar
streeteagle
If you are thinking of getting a high-fllow air cleaner you definetly need to get a fuel manager otherwise you will run way lean, not good. I am running an SE air cleaner with a PCV, runs like a champ.
Old 12-14-2014 | 12:50 AM
jcsshane's Avatar
jcsshane
Stock pipes with Big Breather = No
Free Flow pipes and Big Breather = Yes
Free Flow pipes and stock Breather = No
Old 12-14-2014 | 12:57 AM
RiverB's Avatar
RiverB
Replace it with what? Help us here.
Old 12-14-2014 | 08:10 AM
Oldgreazer's Avatar
Oldgreazer
On my 07 heritage I installed a big sucker, xieds and cycle shack slip ons .it made a big diff. But you will get a million opinions
Old 12-14-2014 | 01:37 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Is your 04 Heritage carbed or EFI?
If it is carbed, for it to run its' best you will need to do a bit of carb adjustment.
If it is EFI, you will want to use some sort of fuel management. The newer bikes will adjust for just an air cleaner, but on the 04 EFI bikes, the ECM is not as good at adjusting for the addition of a free flowing air cleaner.
Here's a good overview of the popular methods for EFI tuning-
https://www.hdforums.com/forum/ignit...uning-etc.html
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
Call/Text: 662-252-8828
Old 12-15-2014 | 12:50 AM
oct1949's Avatar
oct1949
I diff recommend the real K&N filter replacement over the MoCo K&N Paper made one....
Old 12-15-2014 | 11:29 AM
Warp Factor's Avatar
Warp Factor
Why?
And what is a "MoCo K&N Paper made" filter? Are you referring to Harley's cleanable performance filter which is not oiled?
Shadowray
07-03-2016 11:22 PM
jasonleahey
03-15-2015 10:07 AM
1931jamesw
11-30-2011 06:55 PM
roadking1893
01-20-2009 11:52 AM
jtmurph00
Exhaust System Topics
01-27-2008 10:31 AM
Quick Reply: Replace air cleaner?
