Brake light stuck on
The brake light(in the tail light) is stuck to the on postition on my bike. It wont go off. I dont know a lot about wireing. I bought a new brakelight switch or what ever its called and it did not fix the problem. I am bringing the bike into a shop on mondy but was hoping maybe some of you guys could walk me through it. thanks.
RE: Brake light stuck on
I had that problem with my 03 Heritage. On the front brake switch, there's a little plastic tit that contacts the brake lever. Well, it broke off. I was fortunate enough to find it on the floor of my garage and I epoxied it back on. If it breaks again, I have a new front brake switch on standby.
That could be your problem. Pull off your front brake lever and press the switch in. See if your brake light goes out.
I helped a Bud change the front brake switch on a fattie. If you don't already know wherethis switch is located it's inside the the right switch housing. Replaceing this switch is a Bitch to say the least. Haveing his wires inside the bars added to the problem. We had to cut and solder the wires. Good Luck
