Which wire to power the passing lights
2008 Heritage. I am removing the aux light switch( the one on the fork cover), and also getting rid of the front fender tip light. Can I power the black/grey wire coming out of the two passing lamps with yellow wire from the headlight? Any other idea?
Also, not sure how the wiring is on a bike that already comes with passing lamps and fender light but; when I added those things to my 08 Crossbones, I discovered that there were already plugs for both of those things under the left side of the tank. The wire for the passing lamps was just a short yellow wire coming from the headlight wires with a male spade connector cover with a black plastic boot. I tested it and it was hot whenever the bike was on so I assumed this was for bikes with passing lamps. Not sure if you have this spare connector and if you do, if you'r bike is already using it and is set up to be powered by your switch.
americanworkmule (10-25-2016)
The passing lamps that I bought for my Springer were barn-fresh and the wires had been cut. The only wires coming from the lamps were one load wire for each light. The lamps are self grounded with the ground wire connecting to the inside of each lamp housing. I looked at the instructions for a passing lamp kit from Harley to see what their wiring harness looked like. I made my own by simply buying a relay and making all the necessary connections with the exception of eliminating the switch.
That was before I took off the tank for the first time to re-do my bars and found the fender lamp plug as well as a spare hot wire coming from the headlight harness, both on the left side of the bike. I assumed that Harley just uses the same wiring harness for all the Softails and in the case of those models like my Bones with no extra lamps, these plugs are just extras. Harley doesn't bother to "terminate" them from the harness. I was glad for it because I added both a set of passing lamps and a fender light on my last conversion and the plugs were already there.
If I were you and just want the passing lamps on all the time then I would just use the fender lamp wire as a load for the passing lamps. It couldn't be simpler.
This may not be a great idea. From the factory the passing lamps are tied into the low beam headlight wiring. I'm not sure the tip light circuit can handle the load of the passing lamps.
HarleyGTP
07-05-2016 02:58 PM
katanaplanet
11-04-2014 07:41 AM
mile high king
03-13-2012 06:48 PM
