Alarm and battery life
I installed the H-D security and siren module and have left mine for 6 weeks without a battery tender on it and it started right up - I have no idea how long it could have gone.
There is also a small 9v NiCad battery inside the siren, and it could be damaged if the main battery was totally discharged for some time or disconnected.
Any chance that you could use one of those solar panel battery tenders?
A lithium battery would only last longer if it was a higher Amp/Hour rating, but you're unlikely to find one with a much higher rating.
To expand on storage mode, all alarm functions are disabled and the receiver is shut down and will not respond to the key fob. The vehicle is immobilized because the starter motor and ignition module/ECM controllers are disabled.
Basically, the alarm system disables the bike till woken up from storage mode. I don't think it will sound any alarm.
Down South
05-01-2018 03:46 PM
albngore
01-06-2016 05:54 AM
