Show me your motorcycle lift / motorcycle table!
Jacks
I have one of them jacks it's called a black jack also came with adapter for other chit. What are the black things on the jack on the right
What brand are they and how much? I need a set to go on my lift table.
El Cheapo
made this from some scrap lumber i had lying around there is a section that fits between the two wheel support sections and a ramp on the one end i just drive it on and remove the center section and ramp and that gives me access to the bottom and elevates the bike to a more comfortable working height i can also position my red Craftsman jack under it to raise or lower it at will.
I got mine from a place up here called Princess Auto. Our version of Harbor Freight. I paid $60 for each on sale. You can find the same thing on Ebay, in blue I believe. They are each rated for about 1100 lbs (500 kgs).
Hey nikon, I saw another jack post that talked about a strip on heater hose to protect each frame member. Can you put a small piece on the front part of the frame(each side) so the front support of you jack hits the front part of the frame first and helps the front wheel up, hopefully at the same time as the rear. I also like the idea of jacking up the bike and lowering it down on 2 stacked cement stepping stones front, rear and kickstand. Remove the jack for clearance to work on the shocks.
kentuckydave
08-28-2009 08:47 AM
