moving rear brake to left side
Old 10-10-2014 | 11:09 PM
HDKyle's Avatar
HDKyle
Default moving rear brake to left side
I have searched but with no luck. Is there a DIY on how to move the rear brake to the left side to show off the right side of the wheel? I have seen it on softails but not sure how to do it.
Old 10-11-2014 | 07:03 AM
oct1949's Avatar
oct1949
Not sure how it could be done nor have I ever seen one with left side brake, Thinking the pulley for the belt drive might interfere with it.
on a show only bike I guess you could just remove it period...
Old 10-11-2014 | 07:09 AM
Alain's Avatar
Alain
Why would you do that? You'd have to re arrange the shifter.
Old 10-11-2014 | 07:28 AM
JimGnitecki's Avatar
JimGnitecki
He means move the caliper and disk, not the pedal.
Jim G
Warp Factor's Avatar
Warp Factor
I've seen some setups where the rear sprocket and the brake disk were the same piece, leaving the other side open. Can't remember who makes them, and don't remember if they were also available for a belt.
Old 10-11-2014 | 07:39 AM
dfwhockey17's Avatar
dfwhockey17
Old 10-11-2014 | 07:55 AM
Tom84FXST's Avatar
Tom84FXST
Here's mine
Old 10-11-2014 | 08:00 AM
Architect's Avatar
Architect
Exile Cycles sells a kit as well, they call it a sprotor, sprocket and rotor.
Someone else also make a kit with an inboard rotor attached to a belt pulley.
Do some research, they are out there.
Old 10-11-2014 | 10:13 AM
24v's Avatar
24v
There is a Breakout on here with a pulley that is also the brake disc. I will find it.
Old 10-11-2014 | 10:18 AM
24v's Avatar
24v
Here, look for the DNA Brakester.
http://dnaspecialty.com/brakes/
Here is the thread with the Breakout that is using it.
https://www.hdforums.com/forum/softa...kout-mods.html
Quick Reply: moving rear brake to left side
