Alert - Front brake master cylinder leakage on Breakout and ?
Old 09-30-2014, 08:35 AM
JimGnitecki's Avatar
JimGnitecki
JimGnitecki is offline
Originally Posted by martin10
If you over tighten the screws for the cap it will distort the seal and cause them to leak. The spec is only 10 inch pounds. My method is to use the shaft of a screw driver to run the screws in till they bottom out and then go another 1/4 turn. So far I have had no leaks.
That COULD potentially be the cause of the leaks.
I have only ever seen a mechanic use a torque wrench on a master cylinder lid bolt ONCE - that was when the owner at Shamrock Cycles inspected my rear master cylinder for fluid level when I was experiencing rear brake drag due to improper installation of the brake pad spring plate by an HD dealership mechanic. I think most mechanics figure they have sufficient "feel". Unfortunately, some don't have that feel!
OR, it COULD be a bad batch of seals from HD, or a bad batch of lids.
I don't think we really know for sure.
Jim G
Old 09-30-2014, 09:16 AM
usmcbuck's Avatar
usmcbuck
usmcbuck is offline
I know when I took my bike in and showed them, They just said real quick that they have had a few like that we will just put a new seal and lid on it and you should be good to go. So far over the last 1500 miles its been leak proof.
Old 09-30-2014, 10:07 AM
martin10's Avatar
martin10
martin10 is offline
Jim G
Yeah. It could certainly be bad seals. But my bet is that most techs and owners over tighten them. If they are over tightened there is a real good chance they will leak. Just something to keep in mind.
Old 09-30-2014, 03:21 PM
HD and VETTE's Avatar
HD and VETTE
HD and VETTE is offline
Originally Posted by kerplunk38
Mine was leaking, too, at 900 miles. Didn't require any new parts to fix and I did it myself.
Held bike upright. Removed cap and seal. Wiped seal completely dry, reinstalled seal, reinstalled cap, and alternately tightened screws without over tightening. Not a drop in the last several thousand miles.
Most of the time the leaks on master cylinder seals are due to improper installation; the seal was installed wet with fluid on the edges. Once these seals are wet with fluid on the sealing surface itself they will leak.
I TOTALLY agree here I had same problem and did same, took apart cleaned and did same tightening back up no leaks sense. I will also say I noticed a vent in the seal also. Dont over tighten or you will crush the vent along with the seal.
Joanrava
06-11-2011 04:47 PM
twizted81
Wheels/Tires
04-04-2010 08:21 AM
KBFXDLI
11-29-2007 03:26 PM
mtpoland
09-23-2007 09:20 PM
robjohnston
12-12-2006 07:37 AM
Quick Reply: Alert - Front brake master cylinder leakage on Breakout and ?
