Mounting passing lamps/turn signals without the bar
Old 09-22-2014 | 10:51 PM
katanaplanet's Avatar
katanaplanet
Default Mounting passing lamps/turn signals without the bar
2008 Heritage.
I installed a triple tree set which has holes for mounting anything only on the lower trees. I can cut the ears which go into upper tree. Is there is a way/adapter to just install them individually on the lower tree without using the bar at all?
Old 09-22-2014 | 10:55 PM
Snowyone's Avatar
Snowyone
Default lighting
They make a bracket that mounts to the side of the trees for a RK that holds the spot and turn. Maybe adaptable to your trees-they're both FL's though there are differences for sure.
Old 09-22-2014 | 11:48 PM
katanaplanet
Who sells them?
Old 09-23-2014 | 12:13 AM
katanaplanet
I guess its easier for me to fabricate an L shaped bracket. One for each side for the lower tree only.
Exsomos
08-24-2017 02:18 AM
mo cajun
12-31-2016 09:20 AM
73impala
12-23-2015 08:32 PM
Vinish
08-02-2010 09:09 PM
bogie
03-15-2006 05:03 PM
Quick Reply: Mounting passing lamps/turn signals without the bar
