Cleaning inside headlight and passing light
Cleaning inside headlight and running lamps
Yes, I have cleaned inside both the headlight and running lights.
Take lamps off, remove bulb (remember not to touch the bulbs with bare hands).
I use IPA (isopropyl alcohol / rubbing alcohol) as the cleaning agent.
Small piece of paper towel, lightly soak with IPA, use forceps to hold the soaked paper towel, work it around on the inside of the lense until clean, let it dry, install, clean and good to go.
Makes a difference and clearly removes the haze.
propflux01 (06-10-2022)
I have seen discussions about this. I need to do this myself. The simplest thing to try was removing the light and putting a small amount of rubbing alcohol in there. Then swish it around to clean the lens. Pour out and repeat till its clean. I hear there is no residue? And the light will be clean. The rubbing alcohol will evaporate leaving the inside of the dry as an be.
Seems simple...... I hope it works.......
