Set/Resume Switch
P0057 is "Cruise Control Inoperative." There is a diagnostic protocol for your problem in the 2008 HD Electrical Diagnostic Manual, page 4-143. Stop by your local HD store Service Dept. and ask to take a look at their copy. It may very well be the set/resume switch. Yes, HD sells the switch, though I don't have a p/n for it.
Carl
Carl
Pix (07-12-2024)
AndyRanchero1963 (07-11-2024)
just got my bike back from the shop for the same reason, the dealer first replaced the ECM with updated version i have one of the earlier 08's, [ still under warranty ] mechanic took it for test ride cruise control still was not working right, next they replaced speed sensor now it is fine. if bike is still under warranty let dealer repair it
Unfortnately I am out of warranty. So...... It will be me myself and I doing the troubleshooting. I am afraid this is going to turn out to be an ECM issue on mine. Here is what I know and where I am going with my troubleshooting.
1. When I am having trouble, I believe the ECM has the cruise still active but is in Decel as though I am holding the switch to SET/COAST. The Cruise light stays "Green"
2. If I hit brakes, pull clutch or roll throttle fwd. The Cruise light goes "Red."
3. I can also get the light to change to "Red" by pushing the switch left.
(According to the Electrical Manual, the cruise will disengage if both the SET/COAST and the RESUME/ACCELERATE switches are press at the same time.) ****That would be kind of hard to do**** But, in my mind explains why pushing the switch to the RESUME gets the cruise to disengage.
4. I ran through the CRUISE INOPERATIVE DIAGNOSTICS. Everything checks out on that. Light goes Green/Red as required for all functions.
5. According to the manual the SET/RESUME switch should show continuity through the O/W wire tied to the Right Turn switch and the Stop Lamp switch on pin 1 of the connector from the right hand switch housing. I found that to not be the case the continuity is through the Run/Stop switch.
5. I removed the ECM and Ohmed out pins 22 and 34. Each shows continuity to Pin 72 as expected when the Set/Resume switch is operated.
At this point, I don't see it being the Set/Resume switch. I have zip tied my Fluke meter to the Zumo mount and tapped the SET/COAST wire and garage tested that I get 12V when I push the switch to set.
And falls back to 2 volts when I let go. (Not sure whether the 2 volts means anything or not)
Now it's raining!!!! no road test.
