Throttle Troubles 2017 Dyna Low Rider
Old Yesterday | 12:37 PM
anjing7684's Avatar
anjing7684
Stage I
Default Throttle Troubles 2017 Dyna Low Rider
I have a 2017 Dyna Low Rider, I purchaced new in 2017. A little over 2 years ago the bike started idling low, I'd hold the throttle open a bit to keep it from stalling and then i became concerned with overheating riding in city traffic. The bike is a daily rider. I brought it to a local shop they streightened it out with a new battery. I installed an ultra cool oil cooler to help with the overheating concerns. The bike ran good for about 4 months then more of the same idle issues. I cleaned the Idle air controler and things were good for a month. Then more problems. I replaced the idle air controler and the throttle position sensor and things were good for a couple months. but still bock to the same: irratic idle, sputtering when giving it gas starting off from a start and engine deying and not starting back up. I changed the intake air sensor and things were good but then the same. If i unplug the throttle position sensor it will start and run but kind of crappy. I clean my air filter regularly with oil change at 3,000 miles. I recently 45k miles changed the fuel filter it was filthy, black. The bike ran great like new for 3 weeks and then back to the same nonsense. I had also changed the engine temp sensor. Any ideas? I'm getting ready to replace the TPS plug.
Old Yesterday | 02:07 PM
2500hdon37s's Avatar
2500hdon37s
Are you using an oiled type filter? if so you may be over doing it on the oil and if so I'd suggest a full cleaning of the throttle body and IAC.
Also I'd check for intake leaks.
Are you running any sort of aftermarket tuning on the bike?
Old Yesterday | 07:08 PM
John CC's Avatar
John CC
Interesting. You've replaced at least 5 things, and each time the problem goes a way for a while, then comes back. I'd be looking for something you've done each of the 5 times other than replacing a part. Also, if you have any of the old parts, you could try reinstalling one of them and seeing if the problem again goes away for a time.
It seems highly unlikely that you had 5 different parts fail, all at similar intervals, and all causing the same symptoms.
Old Today | 05:01 AM
BlueridgeXL's Avatar
BlueridgeXL
Checking for intake leaks is a good idea. A DJ-PV or a logging device on the TPS position would help too.
Read somewhere, sometime ago that shutting down the bike with your hand on the throttle grip is a bad idea. Thinking back, that was attributed to a high idle because the TPS leans a -0 with your hand rolling forward and then the true 0 is elevated. I haven’t confirmed this myself, just spitballing.
Good luck
Ramon Barraz Jr
General Topics/Tech Tips
08-11-2024 06:58 PM
hitman1267
12-16-2022 09:30 AM
liverdeluxe
08-09-2013 10:02 PM
FastHoss
06-22-2012 09:32 PM
edeluxe07
06-27-2010 09:00 AM
Quick Reply: Throttle Troubles 2017 Dyna Low Rider
