06 FXDI Super Glide died while riding
On side of road tested for spark, no spark, fuel pump primes ok, Trailered home.
After reading thru forum, thought it was the CKP SENSOR, ordered one, installed it, cranks & won't start, cleared error codes P0151/P0152/P0373
Tested spark again, front plug no spark
Checked and cleaned fuse ends.
Could it be the relays,?
Max Headflow (10-23-2024)
I tested spark with other plug out of cylinder, didn’t check plugs. Bad coil? ,ECM?
You can also squirt a little gas into the intake to see if it will sputter / run a little.. Don't set anything on fire..
The following 2 users liked this post by Max Headflow:
paulmedford (10-24-2024),
pgreer (10-24-2024)
Next thing is to check fuel pressure.. If you disconnect the fuel line from the bottom of the tank, does it spurt a little gas? Might need a fuel pressure gauge..
